2007 RM250 Fork Oil way off
The manual says the forks use 350ml, I pulled mine apart today and measured 500ml.
They have been serviced in the past by a reputable shop.
I also read that the forks have an internal chamber and external chamber, is it likely that the internal chamber leaked out to the external, and thus 500ml instead of 350ml?
Any thoughts?
if internal chamber leak out all oil yor fork havent rebound and comp.you feel no reb before you pulled out apart your fork??on your fork maxim level is 420cc-410cc.with 500cc the fork don t go on last 5-6 cm of travel never!
The forks had rebound before I pulled them apart, they were working well.
Yes to both questions.
Took the forks to get serviced, pulled the interior dampening out and was completely empty, so the inside seals just blew and mixed with the outer chamber.
