Wide ratio KX???
07kx250.I blew my 3rd and forth gears over the weekend,well the dog came of the gear and jammed inbetween breaking 4th gear also.My question is,would any of the klx or kdx gears work to give me a better spread? And do you think its ok to go with a used trans or should I just repair mine? To repair mine is going to get expensive.
I use used transimissions all the time with great results. I have put a 91-94 KDX 250 trans in my 01 http://www.thumpertalk.com/forum/showthread.php?t=1002545&highlight= I am not sure if it will work on a 05-07 but I think you can do it. I talked to 2srokenut when his was apart and sent him a 03 2'nd gear and it fit fine so I'm thinking I could do it to the newer motor too. I am hoping he will send me his old cases to test fit the KDX trans into. BTW I have a 03 3'rd and 4'th I could sell pretty cheap and I think they are the same but not 100% sure. Good luck
Ed
