350xc-350xcw motor
Is the motor the same on the 350xc and 350xcw beside the transmission??
The XCFW motor is a bit different: Lower compression ratio (12.3 vs 13.5:1 on the XCF), bigger flywheel, heavier crank wheels, plus different cams that give better low end torque.
I own both a SXF (same motor as the XCF except for the gearbox) and a EXC-W (uncorked), and I like the EXC-W motor a lot better.
