X-light motor Bigbore ?????
Hi!
Is still available BigBore kit for X-light motor ???????????
Like Te,Tc and TxC 250 2011-2012.
Thanks
Marc
I dont think anyone makes a bolt on big bore.
I just made a 2010 txc250 into 310 with oem parts from husqvarna.
Had to get a crank, piston, cylinder, head bolts, cam chain and cam chain guides.
Didn't get a chance to ride it yet.
Wow, how much did that cost? I wonder if you can make a 2012 TC250 with the new head into a 310.
wonder about putting a 310 piston in the 250.just the piston .any one try it?dan
The 310 cylinder is taller and bigger bore and the crank is a longer stroke.
i know the stroke is longer and the cyl is taller.i am wondering about taking a 250 cyl and having it bored and then replated to fit a 310 piston kit.use the 310 head gasket .some thing like a 280 would be the result off the top of my head...if it can be done.that would cost about $600 for gaskets,piston kit and the boring/plating.dan
George mentioned yesterday that he was going to check it out and see how much meat is there and maybe make a 270 or 280 kit, whatever could work. He sold 4 new bikes this week, 2 125's and 2 TE 310's so he's been a little busy but who knows.
Forgot to mention that I had to bore the cases for the 310 cylinder.
There may not be much cyl wall thickness if you were to bore the 250 cyl.
I should have checked all that stuff before putting it back together.:lol:
for some reason I thought I remembered seeing a big bore kit in the special parts catalog
