05 kxf oil leak type problem
hi all , new round here but hope to contribute to the forum regularly. ive a prob at the mo i thought you,s might be able to help with.
kxf 250 that had been butchered a bit and needed a camchain and blades replaced as they had been installed wrong and chewed up a lot. rings werent replaced as they were supposed to be new rings in there already . new head gasket,base gasket ,clearances done.
the bike starts fine ,ticks over/revs fine but after a few minutes oil starts coming out of the engine breather hose thats under the carbs, the hose that comes from the back of the clutch housing .its a fair bit of oil .anyone any ideas why ?
using 10w40 semi synth motul in case that makes a difference .
tried it with fresh oil , left the plug out and after a good few kicks the oil came out of the breather again ,took off the plug/screw for inspecting the timing as well to see would it relive pressure as well but it made no difference. probably not the rings then
