01 WR270F Radiator Question
hello all,
im getting the glowing red hot header syndrome and after searching and reading some other threads i decided to break down my whole cooling system and check things out, but to start first, whats your guys take on this radiator? is that too much deformation? what do you think caused that? i havent seen this before....
I've seen worse. It's caused most likely by something bumped it or pushed into it. Glowing red header is kind of normal. You can't let the bike sit and idle, it needs air flow over it. Make sure it's not running too lean.
