what case can i use to convert my 03 wr250f to kick start only
All you can do is take out the starter, gears, and the ring gear off of the back of the flywheel and then figure out how to plug the hole where the starter came out of. I wanted to put an e-start '03 set up on an '02, and the side cover has a different bolt pattern. Also, the crank is different. Maybe an '03 YZ cover will fit, I don't know. The bolt pattern difference is up by where the starter is, I think.
