Couple Jetting Questions
2000 DRZ400E
3x3 Mod
CNC end cap
1500ft
Rejetting my bike:
Main from 142 to 160
Pilot from 45 to 48
CE removed and nipples connected, not capped.
Needle to 5th position
Fuel 2 turns out
Wanted to know if my pilot jet selection is correct since I removed the CE,or should I just keep it at 45?
Also, the main jet I ordered is slightly different in shape, in that it has a wider, non tapered area at the base of the threads, but my old one is just slightly tapered. Wondering if I got the right jet or maybe it's for the mx?
45 pilot jet should be sufficient..
Stock DXP needle on #5 is fine with Snorkel removed?
Your main jet should look like this...This Keihin mj will fit both Slant body and MX versions..
