Fuel Fitting out of Petcock?
Removing the tank from a 2001 DRZ400S I pulled on the fuel line and pulled the brass 1/4" hose fitting out of the petcock. It looks like a press fit from the factory with no sealant. If I just press it back in I gotta think it's going to wiggle free and leak. How should I put the fitting back in to make it secure and leak free?
In the petcock base where the intake tiubes connect there was a lot of rust deposit that fell out . Something like a steel spacer must have corroded away. Is there a fix for this or should I just ignore it and reinstall? Thanks!!
Fuel nipple - Press it back in using Loctite on the joint.
Rust is probably just sediment in the tank. I don't know of any steel spacer.
Reused the factory petcock because wanna keep lil Suzy a virgin. Used blue loctite and pushed the fitting back in. Don!t know what was causing the rust but reassembled with a Clarke 3.9 gal tank and hope no probs. Or as all the
Aussie lifties here in Alberta Canada say. No Worries! Cheers,
True Aussies would say No Worries Mate....:lol:
BTW..What's an Aussie liftie...??
Uhummm you already deflowered Suzy with that Clarke tank. Keep an eye on that '01 oem petcock...like Craigo said it's on borrowed time.
