2011 rmz450 clicker settings.
Please post your clicker settings and rebound. Also what riding conditions (track,desert,trails,ect). Went to the track today and just can't seem to get the perfect settings, really close though. So just want to know what everyone else has their settings at. I did use dirt riders settings but felt as if it was way to stiff and I took 10ml of oil out of the forks, huge difference. Okay post away
SAG and springs rates are gonna be key to balance the bike and allow it to be ridden.
Do I need to buy new springs or can I change the rates the way the bike is? I think it says in the manual right?
the manual shows you how to set sag, if you can get the sag within spec without running out of adjustment I think you probably have the right spring. for clicks 11 clicks out is factory and works pretty good, if your really fast you probably want to try 9 clicks out front and rear, 9 for rebound. the 14mm bolt on the top of the rear shock is for high speed compression, 2 turns out is the middle setting
