Oregon need port work.
cam, airbox mod, jetting, pipe would be a good start?
Mods
Airbox cut
Jd jet kit
Drd full system
02r cam
Ap linkage mod
Boysen qs3
Pink wire unplugged
Brp 20mm offset tripple clamps
Scotts damper
suspension sprung and valved
Raced gp and xc all year.
It needs Head work:thumbsup:
I have an 07 crf 450x and i need wore power.
who does good portwork and isn't gonna cost me a ton of cash.
Joe with I-90 Motorsports in Issaquah (425) 391-4490 does very good work. He has done lots of work for me and all turned out GREAT.
Paul
RB Designs ? In Beaverton.... I'm not sure he does that type of work, but he is excellent and very resonable in terms of cost.
Nick rhines with rhines racing, or fire 1 from camas. He does all the motors for the fast kids in the area
mailto:fire1racing@live.com
Do not think he does that type of work.
exactly. :lol:
Check with Thumper racing about big bore kits.
I'm a big fan of cubic inches, myself. My 04 570SX KTM has stock 41mm carb, vortec ignition, ( 8 slower settings, 1 HEE HAW setting) didn't really need it. Oversize valves ( bent one, why not?) mild chamber clean-up unshrouding the valves, a hot cam and stock exhaust with White Bros. E2 muffler. Pulled extra flywheel off right side, but added bigger EXC stator and flywheel to run big lights. And the 99mm piston(4mm oversize) is 11:1 compression so it's not fussy on gas quality.
Couldn't ask for a better motor, makes power right off the bottom, pulls clear to the top, no big hit or surge anywhere, just tons of power on tap.
Makes my 2010 450sxf feel like a 250F.
If I could fit the 570 in a modern chassis that turns like the 450, I would.
No, don't tell me, I don't wanna know!!
Enough project bikes as it is.
I only pull the 570 out when the ground is soft and I can use all the power without fear of injury.
Ron used to have some pictures on his website of ported 4 stroke cylinder heads so I know he does this work. - I would have Ron @ RB-Designs do the work over anyone else, if he is willing to do so. Ron is meticulous and used to work with the yamaha road racing team.
jeff
jeff
You might be right and yes, Ron does fantastic work. I have had him do several cranks recently and he is about to do a head and carb for me. he does not list porting in his services but maybe he does do it.
Update: just got off the phone with Ron and he does not really do any porting at all any more. Moved on to other services that fit his small shop.
