2004 YZ125 crank gear bolt
I'm working on a 2004 YZ125 and it needs a new crank. The bolt that holds on the gear at the crank, is it regular thread or reverse?
On the 250 it's regular thread.
This bolt typically has red loctite on it. They can back out and cause damage, so make sure when you reinstall to torque it properly with red loctite.
Use some heat and give the head of the bolt a few smacks with a hammer to shock the threads.
And since you're not using the crank again, pull the clutch off and hammer the bolt out with an impact.
