squishy front brakes
1999 yz400
The rear brakes are nice and firm...the fronts are super squishy. I can squeeze the lever straight to the grips without much effort. Now mind you that the bike would endo if I squeezed the brakes that far. I just prefer to use two fingers on the brakes and clutch at all times and I can't quite do that with these brakes.
The pads are new, and today I bled a bottle of fluid through the system. I followed all the normal procedures for bleeding, I used a tube with two full turns to catch air bubbles, and I would build pressure on the lever and loosen the bleeder. I've bled a lot of brake systems in my time and I am pretty sure that there is no air in the system.
Are the brakes from this bike just squishy or is there anything else I can do to make them a little stiffer?
