2001 TTR125L Oil Leak at Shift Shaft
Hello,
I am new to the forum. I have a TTR125L that has developed an oil leak right where the shift shaft goes into the engine casing. It looks like from the parts schematic (on-line diagram) that the oil seal can be replace from the outside. Is that correct or do I need to take the engine apart? I order a new seal on-line.
Anyone know?
Thanks,
Bob
:lol:
Dood, its SOOPER easy. Youtube has a really good video of a guy showing how to do this on a KX, same thing. Takes 5 minutes if you never done one, 2 once you know. Go change it before the other TTR regs have you changing your pilot jet to fix this problem.
