2002 XR100 front and rear suspension question
I have a 2002 XR100R. I was looking to (hopefully) put cr80 (or any other two stroke smaller bike) forks / rear shock on my bike without any whelding or major modifications. Anyone who has any info would be greatly appreciated. Thanks!
cr80 front ends will bolt on up to 1986 model year with not modification. New tapered stem bearings work best.
There are no direct fit cr80 rear shocks.
So anything cr80 1986 or older will bolt up? Thanks!
Not sure how far back but I have a set of 1986 forks (disc brake). Research showed the 87's and up won't fit. On a positive note though, the brake and rotor's interchange from 86-current.
Again rear shock does not direct fit. Moving the upper mount is required.
I have a brand new bbr rear spring for sale. Even have a spare rear shock if you need it. Email george0123 at aol if you are interested.
