really need some help here
cant get new bike to run right. popping on decel without riding it. this is whats been done--
jb weld block off
opened up top only of air box
needle in 5th position
165 main
55 leak jet
48 pilot
no air leaks found
took off carb and cleaned it good.
full system leo vince exhaust with quiet core in. system designed to run with no jetting changes.
have fuel screw out 2 1/4 turns, popping less than it was at 1 turn out
i have a 50 pilot jet but told that it is too big.
not sure where to go from here.
thanks for any info.
Sounds like an air leak to me, check all the boot connections on the intake, also Hot start. Then check for an exhaust leak, start at the crush washer on the header.
i sprayed brake cleaner all around the carb and boots when running and idle never changed. it ran the same with the stock exhaust as well. hot start is clean and on tight with no kinks
If you did not remove the hot start plunger and inspect it, you don't know if it's leaking. It get's stuck part way in the plunger cavity, and leans the mixture.
