06 250R forks and 08 450R forks the same besides the guts?
Wanting to know if 06 250R and 08 450R forks are the same besides the difference in the guts inside. I realize they are shimmed different. Wanting to put a 06 250R set of forks on my 08 450R.
Thanks in advance for the help!
( I am assuming you are talking about the CR250R two stroke) I believe the fork lug offset is different between the two. If I recall correctly, I believe the brake caliper mounting is not compatible either. So for your case, any 04-08 CRF450R or and 04-09 CRF250R forks will work.
yes the outer dimensions are the same. Inners on the 08 is more than just shims.
It is not a direct swap. The fork lugs are different between the CR250R and CRF450R forks.
The lugs are the same CR250 CRF250 and CRF450 05-08. lengths are the same 06-08
