08 rmz250, question on items inside
hello, I'm changing springs in the forks of an 08 rmz250 and replacing fluids. upon breaking them down there was no fluid in the inner chambers (550 outer) and found what i believe to be aftermarket oil lock collars and preload rings (1.5mm, 4.0mm) above the spring seat. this is my 1st time in an rmz fork, could someone tell me if this is stock. its a new bike to a friend of mine and want to get this thing stock prior to making further adjustments, thank
1st time uploading photos
I saw the green oil lock collars on a set of CRF450X forks as well. Im curious to know if they are stock or aftermarket as well.
As far as the preload spacers, they appear to be stock because it doesn't look like the peening at the bottom of the IC tube was sanded/grinded/etc.
The Spring seats are interesting as well.... (I haven't seen the insides of the suzuki forks either).
