XR/CRF 50 parts on 70's
When searching for parts for my xr70, I see that the parts for 50's are much more abundant and cheaper. How about a list of parts that fit both.
I am curious first about the exhaust.
how about the airbox or even a head?
if you know of some interchangeable parts, please list them, I have been unable to find a source for this info
50 parts that fit:
chain tensioners
chain slides
controls
skid plate (most)
crank shaft
engine timing cover
I've got a 70 head on my 50/88 but the 50 heads have smaller valves. Everything with the engine is interchangable. 50 exhaust I think are shorter with diffrent mounting spots but not 100% on that. Do a search on here and you should come up with all the answers you need, I'm sure this topic has came up thousands of times by now
all of my exhaust interchange...they have a longer elongated slot at the rear mounting and the can on my Jardine actually will extend on the pipe....you could always fab up a rear mount to suit
my problem with the exhaust is that the frame on the 70 seems wider up top than the 50. the exhaust has a different bend on the 70 which swings it out from the frame.
I should say here that both of my 50's are clones.
Edited by surveywaters
addition
