Stuck Pilot Screw!
My 02 is slightly popping and has an erratic idle so I thought I would make sure the pilot is 1.5 turns out but it seems the damn thing only moves a millimeter or two, its stick. Its the long brass screw right? I've got the float bowl off for better access, any ideas?
You will fully seat the pilot jet into the carb. The fuel screw located out side on the bottom of the carb is what you will adjust to change the air fuel mixture.
