crf 70 carb leaking.
I bought a crf 70 yesterday. It wouldnt start and the gas had that old smell. I took the carb off cleaned the jets out with a guitar string and carb cleaner. I scrubbed all the parts with a tooth brush. The bowl is clean all passages are clean and flow well. It starts and runs good but leaks like 40 hells out of the pee hose that comes out of the bowl. It does it while running or not. I opened it back up and cleaned the crap out of the thingy that the float controls and it still leaks like a 79 ugo. :lol: Any ideas?
Sorry to say this but you'll have to pull the carb again and:
A] Using carb cleaner and a Q-tip, clean the needle and seat. There is a little rubber tip on the end of the needle that is pressed up to cover the hole where the gas enters as the float rises. These need to be clean or fuel will continue to eneter the bowl. Also a good idea to check the float level while you are in there.
Or:
B] Replace them.
My guess is the float is just not seating.
Might want to try truning the carb on the gasket up just a little from the side it leaks also.
The float could just be not vertical.This has worked for me on a bike like this the kids ride.
I cleaned it out and scrubbed the stopper thingy that thr float controls with carb cleaner and a tooth brish. a friend if mine said that the ethanol crap in fuel can cause the plastic float to swell and will be tight on the pin that holds it in place so it doesnt move freely. I am gonna try again tomarrow and will give feedback. Thanks.
make sure there is no fuel in the float too, they can slpit sometimes and won't float.
Best suggestion so far has been to replace the float needle; buy a carb kit.
yeah..get you a complete carb kit off the Ebay...comes with all gaskets/seals/jets/and needle...seat
Personally I wouldn't recommend using any parts other than genuine keihin, I have found that just b/c a knock-off jet says #62 doesn't necessarily mean that the orifice size is the same a keihin #62 :lol:
good point about jet sizes. I have also been drivin mad by cheap bowl seals! They only fit once, then when you remove the bowl and try to reinstall, the rubber seal is 1/2" too long!!!!! By quality and ve in the long run.
