2007 KX250 horse power
I just picked up my first KX . It's a mint 2007 KX250R 2 stroke with a Pro Circuit Platinum 2 pipe and a Twin Air filter on it . It rips !
Just wondering what sort of horse power this thing is putting out ? Anyone have any idea ?
tie it to some horses and pull, that's how i check all my vehicles. remember to start small with just a couple of horses then keep adding as you go. hold your front brake if you want to know the brake horsepower. tie the rope to your rear sprocket if you want to know what it puts out at the wheel. crank horsepower is a little more difficult as it involves removing your side covers. a donkey will work as they are quite strong, but not as strong as a mule or a horse. also make sure you use a live one to get accurate readings. hope this helps and good luck!
