problems pgmfi setting tool
hello i have problem with the setting tool . evrey time i try to data read i get the messiths ""the ecu can not be switched to data transmission mode"'
someone knows the sulution
Don't plug the harness into the computer terminal until the program asks you to turn on the Ecu setting switch.
thanks , its working now , have to chance the comport from 3 to 4 and its ok . have you do the first time to data write (so far as i can understand te manual ) to the ecu or can you read the stock ecu setting the first time .
