I want to unlower
I bought a used 2010 husky txc250 that was lowered by the previous owner.
It has the KYB forks. I had them apart and pulled a spacer out from the inner chamber. that was approx. 3/8 thick. The springs measure the correct length according to the manual. It seems there is something missing like I could use a longer spring. When the forks are assembled there is no preload on the spring. When compressed there is about a 1/2 inch of movement before you can feel spring pressure.
What could I be missing?
Edited by joedit
