yz250f jetting
i have a 03 yz250f and i bought it with a fmf exhaust on it and i dont think it was re jetted so i was wondering what the setting would be if i should re jet it myself and what kit i can buy that isnt to expensive
The JD kit is highly recommended by many users on this forum. It comes with two different needles and a couple of different size main jets. I think it also comes with a leak jet, too.
I would also get a good quality fuel screw with a knob for finger adjustment. JD makes one of those, too.
Start with getting the pilot circuit sorted with the fuel screw, then work on the rest.
Wander around the jetting database at the top. I did for a while and found it helpful. You should be able to find someone that has a similar setup and probably around your altitude also. Might not be able to duplicate their setup exactly but should be able to get you in the ballpark. Clay
