KXF 250 2012 suspension
cud anyone tell me the correct things to do...coz the front right fork confuse me...i read thru an article last nite about setting rider height for the fork...it stated the right side spring preload has to be adjusted to obtain the exact 45mm rider height...but when i measure the static longest fork expand was 33mm...
the fork travel length is shorter than the 45mm rider height...
cud someone explain this...
I don't understand your problem. When you sit on the bike, it will go down farther.
