fuel line
Is the rubber hose that is used for the fuel line and air hoses anything special? Should I be able to pick it up at a local auto parts store or hardware store?
Yes, you can pick them up at your local auto parts store. Just make sure that you get hose that is specified for fuel and has the correct inside diameter. Take samples with you.
I bought a 3/16" fuel line. It's not the exact size, it's approximately 4.8mm and the OEM fuel line is 4.5mm. For $20 I can get 9.8 feet of OEM 4.5mm fuel line through http://shop.thumpertalk.com/ although I'm not sure what I would do with the extra 9 feet.
