Help With Top End Rebuild
Hi guys,
I'v had my 08 RMZ250 now for a year now and as i don't know what "deep" maintenance has or hasn't been done on the bike, i'm going to rebuild the top end.
I'm happy changing piston, timing chain etc, but not 100% about removing valves.
I would like to put new valve seals in whilst its open.
I know just removing the valves are easy using a £30 tool, but will i need to re-seat and replace guides on them even if the valves are still good?
If so can i check if the valves are still good without removing them?
If It must be done (and out of interest) , how much will a shop charge for cleaning up the head, fitting guides, valves and re-seating valves?
Any help appreciated.
Try the appropriate forum. I'm sure you will get the advice you need there.
