Suzuki 07 ltr 450 with athena big bore kit
pull the head, you may have crack it. its the only way i see oil getting into the intake tract. or, even if you have compression, it may be blowing past the rings. you can run a pressure test on the crank case and see if that brings to light anything. if you dont want to pull the head, id ask the sevice teck at the dealership for his/her opinion. besides, what is your compression at?
