Help! TTR-125 Float Valve Parts Replacement
My son's 2004 TTR 125 is having issues with the float assembly allowing fuel to flow freely out of the carb down the drain hose. After taking it apart to fix the 'sticky' float, I decided to pull the whole thing out and look at the needle and needle valve in the float assembly. The rubber o ring and tip on the needle are worn. Guess that is my problem. So.....question is, I cannot find the part number to replace the float assembly needle and valve. Does anyone know where I might find this info or obtain the replacement parts? The carb in this particular 125 is the Mikuni VM20SS. Thanks in advance!!
