Need HELP with tire/tube problem
I have gone through 7 or 8 tubes over the last year. Each one has ripped at the valve stem indicating that the tire is spinning on the rim.
I have used cheap to expensive tubes yet nothing is working.
I thought I would buy a new tire and tube this time to see if that works but am having trouble finding the recommended size tire.
XR 100R
Front Tire (factory) 2.50x19
Will a 70/100x19 tire fit ?:lol:
Maybe you need a new rimlock (?)
I agree with this^^^^
Your tire is probably spinning on the wheel and causing the tube to tear at the valve stem. I'd check and/or replace the rimlock.
I could see how not using the valve stem nut would possibly keep the valve stem from tearing when the tube moves, but do alot of guys do this? I hadn't heard of that trick before.
I like to spin my valve stem nut up against the bottom of the valve cap. When I see the tire has slipped on the rim, it only angles the valve stem in the hole alerting me to the fact I need to break it down and straighten it. Most of my riding buddies do this also.
Good to know, thanks. :lol:
I agree with adding a rim lock. In my experience that is the only cure for preventing tire slippage. If your rim isn't drilled for a rim lock, drill the rim lock hole 180 degrees from the air valve hole.
