Aftermarket fuel screw for xt350
Has anyone heard of or used an aftermarket fuel screw that would fit an xt350?
My fuel screw fell out and I cant order one from anywhere.
I just ordered a fuel screw set for the TT350. It was only 3 bucks so i figured I'd give it a shot. If it doesn't work then ill probably look into those carbs. Thanks
Please , let us know how that works out , good or not .
Yeah I ordered the fuel screw set for the 86 TT350 and if fit like a charm and runs fine. Its idling kinda weird right now with choke(choppy idle and after a while it dies with no throttle) , but once i take it off it runs and idles fine. Its a good solution if you have lost an xt fuel screw, really the only solution.
Any ideas why its idling on choke so weird? Instead of a faster chugchugchug, its like a slowed down spaced apart chug..... chug..... chug. I think im going to pull the carbs today and clean em and take a look to see if anything is clogged because it is also giving me a jerking motion on the freeway at times as if its fuel starved. (this has been happening before the new screw).
Could be a lot of things . Maybe carbs or electrical or even clogged exhaust ( acts like a choke , just on the other end ) .
Well I just pulled the carbs today. There was a little rust from the tank, but no goop and no clogged jets. I have the Exhaust and headers off right now because I repainted them with some BBQ paint so ill take a look inside there.
