What bars? crf50
Just wondering what a decent sized bar would be for my Larger 6yr old on his crf50?? Putting the crf70 clamps on so would like to upgrade to a little better bar etc. Will the crf70 controls? Brake/throttle etc work with the stock 50 stuff? Thanks guys!!
brake will not....throttle would if you also change the cable to one that comes with a BBR big bar setup.....stock CRF50 carb top is connected to the stock cable so you would need an aftermarket carb top to use with the stock CRF70 cable..there are other options out there tho
haro bmx slim bars
there slightly taller than stock
there not as wide
front brake cable and throttle cable should be long enough
the bars are indestructable
my slim bars have been on my 50 for 6 years and havent been bent
and its had a few good crashes
Yep thanks guys. Ive decided Im just going to get the whole Protaper bar kit. Its decent prise at my dealer and it makes more sense than trying to hack all the parts together etc. His bday is in February so it makes sense to split up the parts etc!
