2004 CRF540R fork seal replacement
im looking to replace a buddies fork seals on an 04 CRF450R. what is the correct oil weight and height/amount? any help is greatly appreciated.
5wt oil & not knowing any specifics about what springs, valving etc has been done internally you could start around 350cc's. 325-375cc's is a good range to work with usually....
doc
i use around 400cc but you can start with 350cc is a good starting point,if you have bottoming problem you can increase the oil 10cc at step up to 420cc
