reeds and jetting?
how much jetting is needed when putting in boyseen rad valve? assuming that the jetting is spot on currently? will the bike be better or worse if i dont jet the bike after the reeds?
it changes per bike, but since it is boyeson, you can call their help line and get a hold of a technician and he can tell you what adding that rad valve will do to your jetting, almost exactly. RM125's need a bigger main if you put in power reeds but the other setting stay the same. other bikes will be different.
