Mikuni tm flat slide
Hey all im in the process of doing a few mods to my xr650r I just got a big gun full exhaust and im looking at putting a carb on it I found a mikuni tm flat slide carb with a pumper does anyone know if it will fit and if so a starting point for jetting thanks
Sean how hopped up is your XR?
If it's stockish a 22.5 to 25 pilot.
A 135-140 main will work.
you need a 50 or 55 pump nozzle probably a 50.
A y4 or y6 needle jet whichever is leaner.
A 9djy01 needle or similar
and a 1.2 air jet.
This will be close enough to start with,disconnect the pumper to get a starting point.
HTH.
Motor is stock as far as mods go it will just be the exhaust carb and xrsonly hifflow side panle maybe stage 1 cam
