CRF70..bigger bars/free mods
New to the 70s and did the search with no results so here goes...I want to add taller bars to my stock CRF70...do the throttle and front brake cable need to be replaced or is 1-2 inches doable with out replacement?..also I know there are "FREE" mods for the XR/CRF 100 but what about the 70?...exhaust baffle,jetting,airbox?...thanks in advance
you probably will need to get longer cables....they should have a little slack to them......you could drill some holes in the back of the air box...or you could just sell the stocker box and put a few bucks with it and get a UNI sock filter...pull the baffle.....don't ride in a zone that has an easy chance of catching fire because you pull the spark arrester as well when you pull the baffle...might as well be safe than sorry....may have to change jetting slightly...cables from a XR80 may work
