shock shim stack opinion
Here is the deal, my rear shocks on the hybrid (02 KX 125-200 KDX) suuuucks.
I've already had a reputable suspension shop revalve and respring the fork (really made a hell of a difference )
So here is my question for the suspension gurus:
my main complain about it is the braking bump and accelerating bumps: they beat me to death to the point I have to really hang on for dear life
The wheel seems to be bouncing up and down and not track at all, get a lot of wheel spin (I'm convinced that's why I destroyed a brand new michelin S12 in 2 rides )
It seems ok on jumps, i don't bottom out anywhere, so I think the low speed compression and rebound is ok.
My shock is apart for now since I blew the seal on the last ride and I was thinking about trying something to make it more rideable. (riding on a blown shock is like having a pogo stick for a shock )
Anyway here is my original shim stack: it looks a little weird
nut
thick washer
new...... old
-20.95 20.95
-21.95 22.95
-21.95 23.95
-22.93 21.95
-22.95 21.95
-23.95 23.98
-23.95 22.93
-23.98 23.98
-23.98 25.95
-25.95 20.95
-25.95 23.95
-27.95 25.95
-29.98 27.95
-33.95 29.98
-33.95 33.95
-33.95 33.95
-20.95 22.88
-22.88 33.95
-33.95 33.95
-33.95 33.95
-33.95 33.95
gold valve race tech
-37.95 37.95
-37.95 37.95
-37.95 37.95
-37.95 37.95
-37.95 37.95
-37.95 37.95
-37.95 37.95
-37.95 37.95
-25.89 37.95
-37.95 37.95
-37.95 25.89
-33.95 37.95
-29.95 37.95
-27.95 22.95
-25.95 37.95
-23.95 33.95
-22.95 29.95
-17.95 27.95
-37.95 25.95
-37.95 23.95
-37.95 17.95
I'm also thinking about dropping the PSI from 170 to 140-150.
Thoughts?
thx
wilf
what is your riding style? i would love to see pics of that bike. i'm interested in putting a kdx motor in a 125 chasis. anyway, what spring rates are you running? is this a type 1 gv, or a low-deflection piston?
trail riding, I'm usually pretty aggressive (well I had to, it seems the slower i go the more beat up I get if that makes sense...)
I don't know what type gold valve it is, I assume it's a type 1, i'll snap some pics if that helps.
Spring rate is 4.9, I could use a lower rate but really can't afford one at this time. The sag # are within the recommended range though.
you can see pics there:
http://www.kdxrider.net/forums/viewtopic.php?t=8245&postdays=0&postorder=asc&&start=20
