couple filter questions
Okay guys i got a couple questions. 1. I have a pit bike with a carb thats 1 and a half inches across, does that mean i buy a 1 and a half inch air filter or bigger? Also do u think it would be okay to clean and oil a uni filter with no toil solvents or will it break down the filter? Thanks alot!
You want to measure the O.D. on the filter side of the carb and order a filter with the correct I.D. size . Most are going to be in mm . If your O.D. is 1.5 inches , that should be about a 40mm filter . You can find em on ebay all day for 10 - 12 bucks . Good luck
