Oversized rotor bracket
So is Motostrano the only place I can get the front brake relocator for the oversized 320 mm disc?
DRZ400SM
Thank you.
DRZ400SM
Thank you.
For what forks are you asking?
SM forks that normally use a 310mm rotor? If so, yes I think they are the only distributor.
If the Conventional Showa forks found on an E, S or kicker, then no. Many places can get them for you.
