rebound stack advice shock
adding 2 face shims on reboundstack crf450 2010 with pc-link 59kg spring ok?
stock stack 54kg spring
reb
40-0.2 (4)
28-0.11
40-0.3
38-0.3
36-0.3
34-0.3
32-0.3
30-0.3
28-0.3
26-0.3
any help would be great
15 for a 54kg spring but thats not enough for a 59kg spring.
The problem is if i want to adjust by closing in ,the shock starts bad because it has almost no bleed (compression) so i want to chance the valving,
thanks
you could put 2 more on and test to see where it takes you, you may want more. the stack is fairly stiff as it is imo.
