Looking for XR carb dimensions
I'd like to upgrade the carb on my XR200. It has a Keihin with the waisted venturi? design that measures 26mm bore, 22mm slide, 48mm ctr to ctr at the flange mounting studs, and apprx 38mm at the airbox bell.
So...if any of you can tell me if US XR 200/250s used to run a carb with a 30mm bore? I'm looking for what year and if possible a part number for an OE XR200/250 30mm that measures out the same as mine.
Thanks
