Bleed stack(low speed adjustment)
ok so i am just curious as to how a low speed adjustment stack(bleed) works what are the effects of different changes. does it work for high speed as well..it looks to me like this has a high and lowspeed stack...this is what i found in my bike.I am confused what the top 16.1's and the 16.2 are for. they are not really a part of the stack from what i can tell they just fill a gap.am i corect?i have revalved my base and my mid i just wondered what you guys know about the bleed stacks to see if i can use your knowledge to help me do some fine tuning..what would i do to get certain effects out of this stack..if i wanted to soften or stiffen a part of my stoke or all of it at once?
here is my current stack
16.1(8)
16.2
16.1
11.2
12.1
13.1
14.1
15.1
16.1
the bleed stack affects the damping during the free bleed , ie before the shim stacks come into play, it stops the fork falling into the stroke so easily, BUT you have to add a lot of shims to make a decent difference in feel.As the main shim stack opens more and more the bleed stack effect is less and less.
