ttr125 - will xr100 cylinder fit?
I saw this add on ebay which makes it sound like the ttr125 and the xr100 cylinder bolt on and line up the same. I looked up the bore and stroke to find that the ttr has a 54mmX54mm where the xr100 has a 53mmX45MM. This add says the cylinder is 120cc on the xr and 150cc on the ttr; the math works.
Is this right?!? If so, the xr100 kits are way way cheaper and easier to find.
