higher compresion
what is de easy way to get a higher compresion . and what comp. ratio is advaiseble .we can ride with 98 ron oct. at a ktm sxf 250 you can use a thinner base gasket but i dondt know if they made it for crf .
The best thing to do is just replace the piston. You can go as high as 14.5:1 compression with 98 octane fuel. You do realize that there is a lot more stress on the bottom end when you raise the compression. It seems like the 13.5:1 isn't too bad on the bottom end, but when you get above that, it seems to beat them up quick. The nice part about the 13.5:1 is that you can run as low as 91 octane without detonation. I prefer 93 with the 13.5:1 just for safe measures.
Piston is the best way. If you run thinner gaskets or mill the head you are moving the valves closer to the piston.
someone experience with ceramic coating in piston top and combustion cambre for less heat and more power
