xr600r cr500 forks, nissin caliper, need 320mm upgrade...
Hello,
Im working with a set of cr500 forks, excel wheels and hubs, and what looks like the stock front rotor and caliper. The pads are pretty worn out on the caliper and the rotor looks like poop and is grooved.
Off hand does anyone know what pads I need? I believe it is a stock caliper. Also what 320mm rotor kit should I purchase that will work with the cr500 inverted forks?
Also any tips on replacing the wheel bearings? I might have a friend help me on that.
The rotor has 4 small 10mm bolts attaching it to the hub with a big black plastic center cover/shield piece. I can provide pics if needed.
