2004 200 SX Stock Jetting
pilot-45
main-188
needle-R1468G
needle postion-3rd from top
throttle cutaway-5.5
air screw-1.5 turns
Straight from the 2004 owner's manual . . .
I actually went with a JD jetting kit to clean up the blubbery bottom end.
Hill, depending on the needle you have in there, the pilot you have may be good. I would bump the main to around stock or a little higher. You may find some topend based on where you are now.
I would start with stock settings, correct for temps, and give it a try, providing all is good with the motor.
Thanks leblanc, thats the info I needed. G, besides a compression check anything else to look at on the motor? PV seems to be hitting about right, to me anyway.
Ok went back to stock jetting. Bike runs strong but a little blubbery right off idle. Wet pipe some running down silencer. Should we look at the main, pilot or needle first? By the way reeds look good.
