Revalving 09 RMZ 450
Working on revalving my RMZ 450. I have the base valve apart and this is what I have.
15-.3 x4
30-2.0
22-.1
23-.1 x 2
24-.1
24-.1 x 2
28-.1
29-.1 x 2
26-.1
29-.1 x 2
20-.1
30-.1 x 6
30-.4
I ride mostly MX, weigh 190 and ride pretty aggressive. Last summer The bike felt ok, but I would like it to ride a little higher in the stroke and soak up choppy terrains.
base
stk
6 - 30.1
20.1
4 - 29.1
28.15
27.15
2 - 26.15
2 - 25.15
2 - 24.15
23.2 b
fork rebound
2 - 20.1
11.15
19.1
18.1
17.1
16.1
15.15
14.15
13.15
12.2 b
2 - 16.3 f
17 x 2.5 w
fork mid valve
mv 7 - 20.1
I had to grind the peen off to remove the nut. I don't think its been revalved or resprung. I got this bike is Aug, the previous owner said he had MCR adjust the clickers and that was all.
the mid is stock,the base is mod.the std valving work good work intermediate rider but i think a little spring on fork work much better.i like a 0.48-49 on fork for first,whit your stack ,without a 22x0.1 .pull out that
15-.3 x4
30-2.0
22-.1
23-.1 x 2
24-.1
24-.1 x 2
28-.1
29-.1 x 2
26-.1
29-.1 x 2
20-.1
30-.1 x 6
30-.4 but what s that???are you sure 30.4 is impossible
look if is not 4 30.1 bonded by oil
The 30 .4 shim is under the piston. Maybe that will make more sense. Here is the mid valve.
washer that is 16 2.46
Shims
15 .3 x2
11 .2
12 .15
13 .15
14 .15
15 .1
16 .1
17 .1
18 .1
10 .15
20 .1 x2
piston
20 .1 x7
spring
washer
plate
8 .2
9 .2 x2
10 .2 x2
Again I had to grind off the peen to remove the nut. assuming this is stock.
15-0,3 x4 15-0.3 x4
30-2,0 30-2.0
22-0,1
23-0,1 x 2 23-0.2
24-0,1 24-0.15 x2
24-0,1 x 2 25-0.15 x2
28-0,1 26-0.15 x2
29-0,1 x 2 27-0.15
26-0,1 28-0.15
29-0,1 x 2 29-0.10
20-0,1 20-0.10
30-0,1 x 6 30-0.10 x6
piston
30-0.4
that s the difference from your then stock
your stack is soft then stock
you need 0.49 spring and start with stock valving
make a ride and give a feedback .that s my think
I am going to leave the springs alone. My weight changes too much, by spring I will weigh less and by the the middle of summer I will be around 175. I would like to get a stack for riding MX and for an aggressive rider. I tend to land hard on the front and have blown the fork seals on every bike I have ever had. I like the front to feel light and the back to stick to the ground.
Thanks
