87 KX500 engine 88 Head
hi guys
does anyone know if an 88 KX500 engine head will fit an 87 KX500 cylinder? The 87 one i am looking at has had its head stay cut off and i was wondering if the 88 head will fit on the 87 motor?
Is it advisable to re-weld some fabricated headstay brackets onto the head that has had them cut off, or will this cause any issues to the head itself from the weld heat?
The short answer is yes it will fit, The design is the same, it may have a different squish angle or compression but will still work. There was one year that had larger studs around the thread area, can't remember which year. as for weliding a new stay, you could probably do it, but you'd have top resurface it to ensure the heard wasn't warped, heck they are welding on fittings for compression releases so I don't think you'd have a problem.
