Raptor 350 oil
Hello all, just bought a raptor 350 for the wife, did not get an owners manual. Im curious if I can use the same oil I use for my yzf 450 on the raptor 350 to do an oil change. Just for convienence.. I use Rotella 5w40 synethic on the 450? Thank you
Also, if anyone can give me a quick oil change procedure that would be great. I believe you remove the dipstick and crank case bolt, drain oil and replace oil through the dipstick with 2.4L without oil filter and 2.5L with oil filter. Is this correct? Thank you
For more info you might try raptorforum.com
There is a link they had posted on raptorforum to get the owners manual which would have your oil change procedure etc...it is a sticky under the 350 heading...you just have to sift through it some and follow the instructions to download.
